Malfunction
My BS2 decided it didn't want to work. None of the cable were altered and the power LED comes on but I still get "No Basic Stamps Found". The only change I made to the circuit was moving some resistors up a pin and after that the stamp isn't recognized. When the resistors were moved - with the power off - the LED display did come on and off momentairly.
I tried reconnecting the USB to the stamp, turned the stamp on and off several times, tried different programs, checked and rechecked connections but nothing changed the resuts.
Ideas?
Ideas?
I think you fried your Stamp 2 chip. If you are using the BOE, it is a very small and crowded breadboard (more like a bread crumb). Before I turn it on every time, I check and re-check to see if any of the LED leads are touching. When found, I use a tweezer to separate them. Then, and only then to I turn it on. The fact that your LED came on momentarily suggests that there was a short circuit. That's why I'm using the PDB now... much bigger breadboard (about half a slice).
Here's how you narrow down the culprit;
1. Try a different computer to hook it up to.
2. Try a different program (download the editor of the newest version off the Parallax website) - you already did this, "tried different programs".
These steps will isolate your problem as a computer hardware/software problem.
3. Try putting your BS2 on a different board.
4. Try putting anoter BS2 on your board.
These steps will isolate your problem as a BS2 problem or BOE problem.
5. Replace the component that is not working.
Try this and see,
Lilly.
·· There is a second BS2 on a different board with a different power supply, it accepts the program without any problems. So now its swap out the stamps and see what happens.
- Use a Needle nose to put in componets. Its a pliers made for electrical work with a long flat snout. Takes about the same space as a tweezers and gives a lot more controll.
The second stamp accepted the program on both boards but the stamp in question didn't.
Both boards ran different power sources and loaded from the same computer.
