What I do is wire up a Prop Plug, and use some or all of PC_Debug, outputting to a little gem called RealTerm. The cost is the loss of a Propeller pin or two. But the gain is full-time, full-bore debugger/data logger. It's way easier than going in and out of Hyperterminal to turn on/off ports, hang up, call in etc etc.
Jeff the author of the Propeller Tool is working on a debug terminal feature, at first it will be much like the Stamp's debug terminal, but he is making it extensible so eventually it will do much more.
Can he add hex scripting, and maybe crc/lrc calculation? I·modified a GNU· vb app like this.... it does LRC with hex or text sending and recieving... your welcome to play with it and use it as you desire. I found it usefull with ICOM recievers, Pump controllers, etc. It is a good app for industrial testing/debugging, it needs some work to save to file/clear buffer of textbox when full, etc.
Post Edited (bassmaster) : 2/3/2007 3:18:09 PM GMT
We typically don't provide release dates because it leads to customer disappointment when dates can't be met. I will say that he is on a month sabbatical at the moment and plans on spending the second half concentrating on implementing this, so hopefully it will be ready for release when he returns, but this isn't a promise.
And note that if he spends his second half of his sabbatical working on this, these guys not only work on their paid
time, but also on their free time. What dedication!
Jim C
Paul Baker
What is the expected release date ?
Jim,
I picked up two plugs, and gave one to a friend. Time to go out in
the cold to find the other...
Paul Baker
