Which power supply to run servos directly off PDB?
Hi guys,
The power supply for the PDB is either 9 VDC and 300 mA or 7.4 VDC and 1000 mA. However, I am holding a standard servo in my hands. Voltage drop from Vdd to Vss is 5 VDC on the PDB. Current is less than 1000 mA or 300 mA, depending on the power supply purchased. However, the servo draws 300 mA at rest and 4200 mA when locked. So, do I need to purchase a 9000 mA or more power supply? In other words, if I want to run standard servos off my PDB, do I need to buy a 7.4 VDC and 9 amps plus power supply?
Lilly.
Lilly.
Dave
Dave Andreae
Parallax Tech Support·
If you want to run the servos off the 7.5V supply, you could put one or two diodes in series and each will drop about 0.7V. The diodes need to be rated for the current.
Is this O.K. then?
P1 is the I/O pin going to the BS2p40 on the PDB. S/+/- is the connection to the servo. 6VDC is a power supply or battery separate from the power system on the PDB. In other words, I don't have to use the PSC nor the 2 servo jacks on the PDB. I can just rig my own connections per the above schematic?
That's a mad tight idea! Ur the best!
Lilly.
Post Edited (latigerlilly) : 2/2/2007 6:52:36 PM GMT
That's called a "common ground", and is needed so the Servo can properly read the "p1" control signal.
And even though the battery '-' is connected to VSS, the battery '+' must NOT be connected to Vdd.
Is this what you mean?
Yes. Sorry. I assumed you knew. You always have to connect the grounds together. The servo and the Stamp use the ground as a reference point for the control signal. It won't work if the grounds are not connected together.
