Bobot .bs2 scripts will not execute LOOP command, — Parallax Forums
ngreenngreen Posts: 1
edited 2007-02-01 18:23 in Robotics
I am running windows xp with usb to serial cable for the bobot,· when I make scripts and run then it stops and will not recognize the loop command,· I have inserted the debug command with out success also.·· What is causing this?·
    You probably have not checked the "2.5" syntax icon at the top of the BS2 IDE. "Loop" is a PBasic 2.5 keyword.
