REPEAT loops
repeat count decreases count once every loop and stops when is gets to zero.· But can I make a loop that loops until I say count = 0?· For example:
REPEAT UNTIL count = 0
·· IF something
······ count = 0
·· IF something
······ count = 0
PUB writestr | p···
··· p := 0
··· print_string(string(13,13,"· Enter starting address to read:· "))
··· repeat until· (msg[noparse][[/noparse]p] :=key.getkey) == 13
····· print(msg[noparse][[/noparse]p++])
··· print(13)
··· sendstr(@msg)
··· print(cls)
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
Here are a couple of examples:
repeat count 'this sets a maximum # times if something quit 'exit the loop if something is true repeat until count == 0 'use "==" here instead of "=" if something count := 0 ' use ":=" here instead of "="Also a cute trick to remember is:
repeat while count if something quitSince Non-zero is considered true. Saves you a logical comparison. (This was done in one of the examples)
Great for things like
repeat while LOCKSET(myLock) ' Halt for semaphor
