Conditional Compiling does not seem to work — Parallax Forums
pauldehaanpauldehaan Posts: 3
edited 2007-02-02 07:43 in General Discussion
Dear reader,
i'm using SX/B 1.51 7/24/2006 and SX-key IDE ver 3.2 and SASM DLL 1.51.07
I'm trying to use the new conditional compile instructions.
I start a new SXb project and insert the example code from the "Whats new.txt"
But.... the result is always the same: " 89 =00000007 LEDS EQU RC ; LEDS PIN RC"
while I expected "LEDS EQU RB"
I thought, maybe I should remove the ' as this makes the lines a comment instead of actual code, but I get a error when I remove the '
How should I use the conditional compile instructions????
'   File...... TEMPLATE.SXB
'   Purpose... SX/B Programming Template
'   Author....
'   E-mail....
'   Started...
'   Updated...
' Program Description
' Device Settings
DEVICE          SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ            4_000_000
' IO Pins
' Constants
' Variables
  '{$DEFINE USE_RB} ' Remove this line to use RC
  '{$IFDEF USE_RB}
  LEDS PIN RB
  '{$ELSE}
  LEDS PIN RC
  '{$ENDIF}
  INTERRUPT
ISR_Start:
  ' ISR code here
ISR_Exit:
  RETURNINT ' {cycles}
  PROGRAM Start
Pgm_ID:
  DATA  "SX/B Template", 0
' Subroutines / Jump Table
' Program Code
Start:
  ' initialization code here
Main:
  ' main code here
  GOTO Main
' Page 1 Code
Page_1:
  ADDRESS $200
P1_Start:
  GOTO P1_Start                                 ' error if Pg0 overruns Pg1
' Page 2 Code
Page_2:
  ADDRESS $400
P2_Start:
  GOTO P2_Start                                 ' error if Pg1 overruns Pg2
' Page 3 Code
Page_3:
  ADDRESS $600
P3_Start:
  GOTO P3_Start                                 ' error if Pg3 overruns Pg4
  • CCraigCCraig Posts: 163
    edited 2007-02-01 14:11
    It compiles fine on mine. But, I'm on SXB 1.51.03 all the rest is the same.
    The .03 might be cause. The new code is a sticky at the top of the forum.
    HTH, Chris
    Bean, will be on shortly, he'll know.
  • pauldehaanpauldehaan Posts: 3
    edited 2007-02-01 14:41
    Hi Chris,
    Stange that is works for you!
    I've also overwritten the SXB.exe file with the new 1.51.0.3 version, but with the same result!
    Do you use the ' in front of all the conditional compile instructions, or do you remmove them (which generates an error warning over here)?
  • JonnyMacJonnyMac Posts: 9,446
    edited 2007-02-01 16:44
    Your usage of the C/C instructions is correct; I just copied your code (above) into the SX-Key IDE and it compiles as expected, i.e., the definition of LEDS is correctly assigned to RB.
    To verify that the SX-Key IDE is actually using the 1.51.03 compiler, click on Help\About, then click on the IDE version number -- it will show you the SASM version. Click again and it with show you the SX/B version. You want to make sure that you are in fact using 1.51.03 (this will also appear at the top of the list file).
    PS: Not that is has any effect on your C/C issue, but you're using a very old template. SX/B has been significantly updated, so I've attached a new version that's up-to-date with the language; put it in C:\Program Files\Parallax Inc\SX-Key v3.2.3\Templates
    Post Edited (JonnyMac) : 2/1/2007 4:59:48 PM GMT
    edited 2007-02-01 17:19
    pauldehaan,
    I used the code as is, cut and paste. As it is, it uses RB. with the following line removed:
    the LEDs where on RC. Like Jon said, make sure you copied the new files over the old ones and the IDE is seeing them.
    Hope this helps, Chris
  • BeanBean Posts: 8,129
    edited 2007-02-01 18:40
    pauldehaan,
    · Did you get this resolved yet ?
    · Like Jonnymac said, make sure the IDE is actually using the 1.51.03 version of the compiler.
    · I did a cut and paste of the code you posted and it compiled correctly (used RB for LEDS).
    · If you look at the listing generated by SX/B (Run->View List or Ctrl-L) you should see at the top the version of the compiler used:
    1                    ;  *** COMPILED WITH SX/B VERSION 1.51.03  09/21/2006 ***
    And then further down you should see this:
        81                                                   ;' ----------------------------------    82                                                   ;' Variables
        83                                                   ;' ----------------------------------    84
        85                                                   ;  '{$DEFINE USE_RB} ' Remove th
        86
        87                                                   ;  '{$IFDEF USE_RB}
        88  =00000006       LEDS          EQU  RB            ;  LEDS PIN RB
        89
        90                                                   ;  '{$ELSE}
        91                                                   ;  LEDS PIN RC
        92                                                   ;  '{$ENDIF}
    Bean
    Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
    "USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
    Post Edited (Bean (Hitt Consulting)) : 2/1/2007 6:44:46 PM GMT
    Dear all,
    IT WORKS!!!
    Thank's for your help
    Somehow, using CTRL+L gave me the number 1.51 without the 0.1 or 0.3 suffix.
    Overwriting the SXB.exe again with a freshly downloaded 1.51.03 fixed it.
