portable pocket tv's
I bought a $16.00 color portable rca tv on ebay but it does not have any input jacks, I added the 560ohm resistor to pin 15 and tried to get the baseband feature working, but the only frequency I see referenced in the code is a used channel 2 5500000, is there a list of channel frequencies somewhere? or a broadbandtv object?
Do look at this thread near the end: http://forums.parallax.com/showthread.php?p=627973
Graham
Another few Ideas: 1·is a gps data logger, that is a one button solution from the trolling motor foot pedal, hit it with your foot and it saves the spot on the sd card. 2. a solar charger for my 3 batteries the cranking battery is charged when the 200hp vmax is running, but the TM 24v system drains pretty quoick in high wind, maybe monitor voltage with the prop and use a small paddle wheel to charge the batteries from the transom.
This is fun.
Post Edited (bassmaster) : 2/2/2007 11:30:20 AM GMT
