PWM Command
Any comprehensive explanation about PWM command, especially when using this command to control DC motor via H-Bridge? And recommendation for Cycles value when driving two DC motors in open loop system, so both motor can spin smoothly with the same RPM?
--chris
Post Edited (Christj) : 1/31/2007 11:39:24 AM GMT
--chris
·· Please see the BASIC Stamp Manual or the Help File within the BASIC Stamp Editor. The PWM command is not designed to run an H-Bridge, but to help the BASIC Stamps to generate an analog voltage through an RC filter. We carry a device for generating up to 4 channels of PWN which is suitable for driving an H-Bridge and can be found at the following link. I hope this helps. Take care.
http://www.parallax.com/detail.asp?product_id=28020
