byte/word/long boundarys ? — Parallax Forums
Don PomplunDon Pomplun Posts: 116
edited 2007-01-30 18:31 in Propeller 1
Suppose I define a table in a DAT area thusly:
DAT
Head byte 0
Tail byte 0
Buf long 0[noparse][[/noparse]20]
If I then pass a pointer to the table ( i.e. @Head ), to a new method as HeadPtr, I envision getting bit (if not careful) by boundarys.
I can read Head & Tail like this:
H := byte [noparse][[/noparse]HeadPtr]
T := byte [noparse][[/noparse]HeadPtr]
But since the rest of the table is Longs, I'll speculate that there are 2 bytes unused between Tail and the beginning of the Longs(?)
To access the first Long in the table it seems that I would use:
N := long [noparse][[/noparse]HeadPtr]
Am I getting it?
TIA
-- Don
    edited 2007-01-30 03:33
    Don,
    Yes, the compiler will guarantee that Buf is indeed on a long word boundary by adding 2 bytes between Tail and Buf. To access the first long in Buf, do "long[noparse][[/noparse]HeadPtr+4]" since the first long (index zero) consists of Head/Tail/padding. To access the k'th long (zero relative) do "long[noparse][[/noparse]HeadPtr+4][noparse][[/noparse]k]".
    edited 2007-01-30 03:44
    Also, if it happens that the argument that is not a multiple of 4, the compiler will round down to the nearest multiple of 4.
    long[noparse][[/noparse]headPtr+5]
    will round down to
    long[noparse][[/noparse]headPtr+4]
    and for absolute addresses,
    word[noparse][[/noparse]$E001] ' in the HUB rom, sine table
    will round down to
    word[noparse][[/noparse]$E000]
    Tracy Allen
    www.emesystems.com
  • Don PomplunDon Pomplun Posts: 116
    edited 2007-01-30 03:52
    "Yes, the compiler will guarantee that Buf is indeed on a long word boundary by adding 2 bytes between Tail and Buf. To access the first long in Buf, do "long[noparse][[/noparse]HeadPtr+4]" since the first long (index zero) consists of Head/Tail/padding. To access the k'th long (zero relative) do "long[noparse][[/noparse]HeadPtr+4][noparse][[/noparse]k]".
    I was waiting for a correction to the above, but I guess it isn't coming ;=)
    HeadPtr points to an absolute address, regardless of byte/word/long (?)
    Buf starts 1 Long = 4 bytes offset from HeadPtr.
    So I would think that the first Long entry in Buf would be long [noparse][[/noparse]HeadPtr]
    Since this statement is only dealing in Longs, I would think that HeadPtr+4 would take me 4 Longs past HeadPtr.
    -- Don
    edited 2007-01-30 04:14
    Don,
    The square brackets that follow BYTE/WORD/LONG are not quite subscript brackets. The LONG[noparse]/noparse syntax treats the value in the brackets as a byte address. I think Tracy is wrong in that the compiler doesn't look at the value at all. It just generates code to compute it. I know (from Chip) that the RDLONG/WRLONG instructions ignore the lower two bits of Hub address given which effectively rounds down to the nearest long word boundary. The RDWORD/WRWORD instructions similarly ignore the lower bit of the Hub address given which effectively rounds down to the nearest word boundary.
    If you give a second set of square brackets after the BYTE/WORD/LONG[noparse]/noparse, the value given is a true subscript. You could write "LONG[noparse][[/noparse]HeadPtr][noparse][[/noparse] 1]" to access the 2nd long word in the work area which would be the first long word in Buf.
    I hope this has cleared things up a little.
    Post Edited (Mike Green) : 1/30/2007 6:55:02 PM GMT
  • rokickirokicki Posts: 1,000
    Correct. The computations are as follows:
    byte[noparse][[/noparse] a ] -> accesses byte at address a
    word[noparse][[/noparse] a ] -> accesses word at address (a & ~1)
    long[noparse][[/noparse] a ] -> accesses long at address (a & ~3)
    byte[noparse][[/noparse] a ][noparse][[/noparse] b ] -> accesses byte at address a + b
    word[noparse][[/noparse] a ][noparse][[/noparse] b ] -> accesses word at address (a & ~1) + 2 * b
    long[noparse][[/noparse] a ][noparse][[/noparse] b ] -> accesses long at address (a & ~3) + 4 * b
    You can also use the @ operator (although this won't truncate bits) so if you want to
    compute
    c := a + 4 * b (7 bytes of spin)
    a "faster" way to do it might be
    c := @long[noparse][[/noparse] a ][noparse][[/noparse] b ] (4 bytes of spin)
    Of course you must really be desparate for space in order to perform such obfuscation.
