possition detection.
I want to have a board that will detect the possition of the users finger. like so:
___________________________
|..............................................| x
| _________________________ |
........................x
x are the sensors
what sensors would i use to detect the position of a finger?
x are the sensors
i was reading that article. It talks about using sound waves for a touch sensor.
Would it be possible to make something like that with the boebot chip?
What about this idea:
could i make something like what is inside keyboards? where the two sheets of plastic with conductors on them touch for a key stroke.
But how would i get that to work with only 16 pins?
also my teacher is wondering how much memory the boebots have on them.
You could make your own membrane keyboard-like device. The trick is to use metal that conducts well and doesn't corrode easily, that's flexible and thin so it moves easily, and can be connected to. Often a thin film of silver is used for this. You might experiment with aluminum foil. Springy phosphor-bronze or brass is sometimes used.
Here are some application notes for other processors that describe the keyboard scanning process. The same idea applies to the Stamp:
www.atmel-grenoble.com/dyn/resources/prod_documents/doc2532.pdf
www.atmel.com/dyn/resources/prod_documents/doc2669.pdf
books.google.com/books?id=4JqlQJd2kvYC&pg=RA1-PA288&lpg=RA1-PA288&dq=keyboard+scanning&source=web&ots=GmvkJ7qw4P&sig=dJ1pshdito6CXr-6yE6M0QwvzjI#PRA1-PA289,M1
Features, needs, wants,·or constraints like those would help you to focus in on the kind of technology you should readily have at your disposal to construct the device.
PAR
i would need it to sense where a point is and then compare it to defined variables for keys.
I was reading that keyboard pdfs. I get what they are saying. Would i need to buy a chip to get it to work?
In terms of taking a "regular" keyboard apart, I don't think you'll find may cables inside. Most modern keyboards are a "sandwich" of plastic film with conductive traces silkscreened on. Some have a "belville waster" or other type of spring either molded into the plastic or glued on to help with the "feel" of the keyboard. All of these traces are routed to a processing chip that takes care of reading the key presses, and passing keycodes to the computer/terminal/etc. via some type of serial connection. Your best bet might be to use the keyboard "as is" and build an interface to read the keycodes. There are probably some hints on this in the Propeller object library, as the Prop demo board has a PS2 port for a keyboard (and mouse).
John R.
8 + 8 = 10
Have you seen this site???
www.virtual-laser-keyboard.com
It might be what your looking for...
Bob
Are you trying to re-invent the no-touch ceyboard, or what is it that you're trying to accomplish exactly?
Bruce Bates
<!--StartFragment -->
Chris asked whether you have a Basic2 Stamp (or other Parallax) programmable microcontroller (that is, is this a Basic Stamp-based project?). Was your "yeah" the answer to that question?
Several others asked what exact problem you are seeking a solution to.
Do you know how to program the Stamp (assuming you have one)?
Here's a project for you (assuming you have a Stamp and will be able to program it).
Make a board big enough to accomodate one switch, which will allow a user's finger to be positioned on it, to press it, and to make switch contact by that action. (Notice that I didn't specify how big the board or switch should be (we know more or less how big a finger tip is), nor did I specify how much pressure to apply before being able to detect the finger tip's presence, nor did I specify why I might even expect a person to want to press the key/switch, nor what reward/result the person would expect to receive. Nor did I specify a lot of other goal, design, costs, deadlines, etc. In this sense, my project specification is similar to yours. But, I think mine is a bit simpler and so it may lend itself to some low-investment effort on your part to build it.
Connect your switch to your Stamp, and write a program for the Stamp which will detect that the user's finger is positioned on (and pressing) the switch (or not). If the user's finger is positioned on the switch (and is making it close the contacts), then light up a red led. Otherwise, keep the led off. One sensor, one position, two outcomes.
For the next project, build a larger board with two switches on it, and write a program to determine whether one switch is closed, the other switch is closed, both switches·are closed·(two fingers involved), or neither switch is closed. Turn on/off the appropriate leds. Two sensors, two positions, four outcomes.
For the next project, do project two but use only one Stamp pin for detecting which switch(es) are pressed.
Then, move on from there to even more complex problems requiring alternative methods, components, programming features·for efficiency or even the feasibility of creating a solution.
PAR
If you shine an LED through the edge of a flat piece of acrylic and touch the surface with your finger your finger will light up on the spot where it is pressed. A camera focused on the back of the plastic could be used to locate the bright spot and calculate its position on a 1" x 1" grid so a 10 x 10 could have 100 buttons. Scoring the surface would create a 1" x 1" grid and allow the data from the camera to process the square that has the finger light up. Positioning the camera at a 45 degree angle to the back surface would eliminate stray light from the camera lens so that it can only see the grid and finger. Reading the surface on a timed basis to compare frames would automatically adjust the sensitivity.
Now Bean has a board that the SX chip used on it could be modified in such a way to count the lines vertical and horizontal on the back of such a piece of plastic so that any grid could be designed with any number of buttons within reason. Even circles and odd shapes could be processed to make it a universal interface for this type of system.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
