Video Amp
· Has anyone added a video amp to the composit video output ?
I would like to run have the video monitor remote
form the propeller. If so what chip did you use?
Thank You
Jim
Thank You
Jim
Could you expand upon your reply a little? What if I wanted to do 4 or 5 bit video or use a R-2R Ladder, what formula do I use to calculate the right resistors to do a good 75-ohm match and get the right voltage swing? I will be building my own video interface for the ProtoBoard and I want to make it better than the demo or HYDRA boards if possible.
Len
can be what you seek.
Page 12 (Figure 6. Typical Video Application)
I ordered a sample and the eval board. I will let you know how it works.
Jim
Unless you're planning to bit-bang the video, three bits is all the resolution you'll get from the Propeller's built-in video generator. And there's no advantage to using an R-2R network for three bits.
As to the formulae, here's what I started with, where R1, R2, and R3 are the DAC resistors, R4 is the resistor to ground, and x || y = 1 / (1/x + 1/y):
····R3 = 2 * R2····;Establish the DAC ratios...
····R2 = 2 * R1
····R1 || R2 || R3 || R4 = 75····;Establish the output impedance.
····3.3 * R4 / ((R1 || R2 || R3) + R4) = 2.0····;Establish the P-P voltage output from the divider.
These are four equations with four unknowns, which can be solved simultaneously to get the right values. Once that's done, the closest values in a table of 1% resistors can be selected. I did this several months ago, so I don't remember whether I solved these by hand or used Derive, which is a math program I often call into play for such tasks. Sometimes, if the complexity is too much for Derive, I'll write a program to solve equations like this numerically, using successive approximations.
Again, I really doubt you'll need a video amp to do what you want to do.
I am going to order three from Digikey (8-SOIC), for another use.
