Need advice on making custom circuitboards
Tumbleweed
Hey All,
A long, long, LONG time ago I made some circuit boards in high school using graph paper, some little black tape, a jug of noxious chemicals, and steady hands.
I'd like to think that the technology has improved since then for people doing at home prototyping and circuit board designs.
Can anyone point me to some software to design circuit boards?
Lance
Lance
Design a schematic and then just dump it into the PCB Design section of Diptrace The Auto route or manually route.
I'm using a laser printer on a Positive Sensitized board and developing them like a film process and etching with Ferric Chloride.
I was doing the Toner Transfer method, but it's a pain to me.
Great Toner Transfer supplies, not hard at all. For design, I use ExpressPCB's software; then print out the layout on Pulsar paper and iron on. Then just dip the board in acid (I make my own with 2 parts 3% Hydrogen peroxide and 1 part Muratic Acid. It many times cheaper than buying Echant and it works better too).
NerdMaster
For
Life
From a post on avrfreaks this really looks good.
http://goldphoenixpcb.biz/
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Paul Baker
I have the board...It's etched, now I want to put a "Silk Screen" what is the best way to achieve this and how do I make them green with the finished look. Whats the best way to do Vias.
Eric
Paul Baker
I really want to have my boards done professionally, but I don't think I'm to that point.. I am working on a Dual motor controller yeah I know.. Reinventing the wheel.. But it's been a lot of fun. I've etched about 3 Boards and am ready to do my 4th.. All have worked to my expectation, but I've added little things as I've gone.. LEDs, Jumpers and Headers. I originally didn't think about until I started using my first prototype. After my 4th board is etched populated and tested I am going to get them done professionally. But not quite yet. It's harder to prototype with SMT componenets. Which is what I've been using a lot of lately.
ERic
Regarding SMT being harder, I disagree, I don't touch DIP parts any longer except connetors, caps, etc. I came up with a very cool system to create a stencil with mylar that you cut on a laser, stretch the mylar over the board on a rigged up stencil printer, squeegie the paste(1 min), place the parts(5 -10 min), oven for 5 minutes and done.
Post Edited (originator) : 2/2/2007 1:07:50 AM GMT
Anyhow this is going is circles..
I Printed my layouts on Transparencies... Expose a board with a bright light for 2 mins etch- 5mins with the Sponge and Rub method and Drill 1 Min as most of my board is SMT... It takes me all of 10-15 mins to make a ready to populate board...Most of the time is preparing (Chemicals and Stuff) The good thing is that once I have the transparency I can mock up another one quickly.
No I don't want to do this forever but it's what I've got for now. I will use one of those PCB houses once I have a working board. Trouble shooting a board is not a problem.. Soldering the SX-48 by hand is simple.... I use Mainly 805 sized dicrete components a tad bit easier that 603. All I was asking was how to coat the board once I'm Done so it doesn't corrode.
Thanks again for all the insight.
Eric
Once everything is soldered on and tested, clean the flux off with 99% isopropyl alcohol and a toothbrush. Then you can apply an aerosol conformal coat. My favorite is Tech-Spray's Fine-L-Coat AR, from Mouser. It's an acrylic formulation that dries hard. (Some conformal coatngs stay soft forever, but make rework easier.) You will have to protect your connectors and switches first with low-tack masking tape or removeable latex goo. Then give the board a generous coating from all directions, and let it dry.
Eric
Paul Baker
Check out the Pulsar site. Besides the toner transfer stuff for the traces, they have some toner transfer for the "silk screen" and they also reference a supplier for some "silver plating" supplies.
In the past, long ago, I made some boards by hand (and may be doing so again soon), and found that if I didn't do "some" type of plating (tin or silver), the copper was very quick to oxidize, and besides looking like he--, er heck, any soldering attempts after oxidation were a pain in the neck.
Other than that, I have no idea of the impact on circuit performance.
The "green" color is normally from the solder mask. I'm not aware of any DIM/DIY products for this, but that means utterly nothing in this case. I haven't even really started to look.
If anyone knows of a _functional_ (as opposed to a purely aesthetic "green" coating) "DIY" solder mask, I'd be interesting in knowing about it.
John R.
Link to My Nomad Build Log
Now I use "Liquid Tin" from MG Chemical. It works great, just dip your board in and it's tinned. But be careful, it's VERY corrosive. DO NOT GET ANY ON YOUR SKIN.
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
For those not familiar with the stuff were talking about (etchants, plating solutions, etc.) they tend to be caustic/corrosive/poisonous, etc. and should be handled with care and appropriate PPE (Personal Protective Equipment), meaing rubber gloves at a minumum.
This is also good stuff to keep away from clothes, any type of eating/food preparation surface (i.e. don't do this in the kitchen) and anything else you care about keeping looking the way it looks before hand. At a minimum, you'll give something a very good, very permanent stain.
As noted above, even the fumes from the etchant can/will have an adverse affect on tools and other metal items.
Now, all that said, this isn't a "don't do try at home" speach, just a "use your head, and understand what you're dealing with" speach.
John R.
I found that for FerCloride, Ajax did the best job to clean up.
