centering my servos? what went wrong?
i was· centering my sevos with the paralax screw driver and i cant get then to work i turned lightly both ways on both of them i cant get the servos to stop??
Im confused advice or anything im doing wrong? is ther any other way to turn the potentiometer
If so (as it should), then you should try an even lighter touch on the turns, so that you don't go past the "home" or "center" or "dead" spot.
If not, then there seems to be a problem with the servos (unlikely both though). If the servos do change direction, but you can not under any manner of light touch get them to stop, I suppose it's possible that those individual servos have a home point that is just too small to hit with the tool/technique given.
Most folks eventually do find they can hit·that sweet spot with a bit of practice, so give it another·try.
PAR
Post Edited (PAR) : 1/27/2007 5:37:49 PM GMT
Sooner or later, you should trip across a description that looks eerily similar to your own dismantled servo(s). Then you should be able to inspect the pot to see if it is damaged or if it's readily adjustable and/or fixable·while you have the servo opened up.
PAR
