ezLCD-004 SD as data storage
Have any one used the SD card reader build-in the ezLCD-004 as data storage?
I have a 2 GB card ready to use as data storage.
Go to ezLCD.com Products··· and scroll down to support link. There you will find a forum. Join it and you will find the 2.9 firmware with the info you seek.
There is also some spin code to get you started with the screen. The SD code is in psuedo C type code but you should be able to decipher it!
Good Luck.
