Flash extra EEPROM?
Hi.
I have a Propeller propstick and I could really use some extra memory for some mapping data.
But what possibilities do I have?
I would prefer a solution which does not require to much soldering/electronics work.
Any ideas? Suggestions? Links?
Best Regards.
Lasse Thomsen
Best Regards.
Lasse Thomsen
It's fast and easy data storage. Plus there are a lot of objects to support such devices.
Im not sure how much data im going to map, but better safe than sorry.
You can download the file system support for the propeller from
http://tomas.rokicki.com/fat16work/
It takes what, 4 pins to drive an SD card? and that's if you use the card detect line.
http://www.sparkfun.com/commerce/product_info.php?products_id=136 <-- so this is what im looking for, and then a SD card?
But im guessing that i then actually could use a SD card with a 4 wires soldered directly on the SD card and onto the propeller?
just followed your link - yip that should do it
Post Edited (QuattroRS4) : 1/27/2007 4:13:14 AM GMT
