SX IDE, SX-Key, SX/B for Windows ME
![Zoot](https://forums.parallax.com/uploads/userpics/559/nW4UO23UEIWZ4.png)
I've been hankering to start using the SX chips, but the only PC around here was Windows 95 machine (we are primarly Mac and I don't run virtual PC).
A colleague just dumped an old HP desktop on me while moving offices. It's got an 850 MHz AMD Athlon processor running Windows ME.
Will the SX IDE and SX-Key run on Windows ME? The machine has two serial ports so I'm not worried about USB driver issues.
(The same question goes for the Propeller and Stamp IDEs, too, actually).
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
If I download the SX software and install it, and it runs, could I figure it will be OK? I wouldn't have a way to dump a program to an SX and check all the way through.
There is no official support for Windows 95 or ME, but as far as I know, there is nothing in the code that will prevent them from working on either OS. Downloading, installing, and running the software will give you a pretty good idea of how successful you'll be. The communications code that talks to the SX is all handled using plain Win32 API calls, so they should work fine. I believe you'll be fine.
Thanks, PeterM
So, the feeling seems to be this will probably work??? (there is a standard D-sub serial port on the front of the machine)
That would be so cool. Because I'd order an SX-Key and some chips quickly
The propeller IDE won't work on anything earlier than win2k, though, but that's because it uses some library that isn't available for the win9x systems. But the SX code works just fine.
David
