Unless I'm mistaken, most if not all of the Motor Mind Modules will accept a tachometer (tach) input. So long as you can provide that appropriate tach input, I suspect your problems are nearly over.
There are also specific MMB commands for dealing with the tach input, again as I remember. Please check the MMB documentation for details on the specifics of the tach signal, and where to connect it on the MMB module.
Good luck with it!
Bruce Bates
<!--StartFragment -->
