Gerber
nwojesse
I need some help. How do I take the Gerber files from the BASIC Stamp and use them on a Modela milling machine. I've looked at the PCB Design and make and none of the file extensions are accepted. So I guess the question is: What program do I use to make the Gerber Files into tool paths for Modela that is free?
Jesse Anderson
Jesse Anderson
...But these aren't straight gerbers...
- Stephen
Some time ago, I posted to another thread a link to an article providing a simple Introduction To G-Codes, ·(http://mcglothin.us/RobotScrapbook/CommunityPcbMill2005/IntroductionToGCodes/index.php).· About half-way down (or use the "Gerber Files" link at the top) are the details about the OEM Basic Stamp PCB.
HTH,
Daniel
Excellon is the drill file associated with PCBs; and it too is a variation (or dialect) of G-Code.
If you want isolation milling (similar to what NewZed does, see especially near the end of the PCB Mill thread), I think there are programs that take Gerber files as input and produce a mill's G-Code for isolation milling as output. I know that, for example, the Eagle schematic capture tool has an output tool (plugin) that produces the isolation milling G-Code for a typical mill.
HTH,
Daniel
