Sx48 - pwm — Parallax Forums
Sx48 - pwm
SailerManSailerMan Posts: 337
edited 2007-01-23 18:05 in General Discussion
I just purchased an SX48 specifically to use the PWM feature of the timers.
Can someone help explain how the·Clock speed say 50 mhz and Timer R1 and Timer R2 effect the PWM output. What is optimal for a PWM Frequency. What are some good settings.
Any help or insight would be greatly appreciated,
Eric
  • BeanBean Posts: 8,129
    edited 2007-01-23 17:26
    Eric,
    It depends on what resolution you need.
    8 Bits = 256 clocks = 50MHz / 256 = 195.3125KHz PWM Frequency
    10 Bits = 1024 clocks = 50MHz / 1024 = 48.828125KHz PWM Frequency
    In SX/B you can simply use "TIMER1 PWM, value, 256" for 8 bit or "TIMER1 PWM, value, 1024" for 10 bit.
    Bean.
    Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
    "USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
  • SailerManSailerMan Posts: 337
    Thanks for that... It ties it together for me. I totally understand. [noparse]:)[/noparse]
