Lowest voltage
Curious if an SX can be run at 1 - 1.5 volts if you run it at the 32 Khz clock rate or would I have to go to 3 volts?
The application may be a small AAA powered device that connects to an over the counter pocket GPS that would vibrate alert if you drop below a preset speed or arrive at a given destination.
Thanks for your thoughts,
Jason
Jason
2.7V is the minimum…But even so, using the internal OSC will not give you enough accuracy for serial input so you really wouldn’t be able to read the GPS unit reliably without a TTL OSC, resonator or crystal connected anyway. Out of curiosity, what powers the GPS module?
FYI: It will accept the NMEA-0183 data
http://store.wmjmarine.com/-c15139.html
http://www.gpsinformation.org/dale/nmea.htm#2.3
Jason
Thank you, Thank you,
Jason Falliable
"The best place to do things is on a whim"
"When its all said and done your finished"
I just finished a project which very clearly demonstrated that... :S
