Help!! serin problem — Parallax Forums
danlodanlo Posts: 5
edited 2007-01-26 04:24 in BASIC Stamp
I want to receiver a string, and then write·it·into EEPROM
There is my code
'EEPROM
Totalprice··· DATA·· 0
price·········· VAR···· Byte(5)
'Program code
· SERIN 9,813, [noparse][[/noparse]STR price\5\"#"]
· DEBUG STR price
· WRITE totalprice,price
For example,
price = 321, totalprice should be equal to 321
but the real result of totalprice = 3, only write the first character of price....why?
What wrong of my programming code? Please Help!!
Post Edited (danlo) : 1/23/2007 12:08:37 PM GMT
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2007-01-23 12:36
    danlo -
    When you read in the string you did so this way:
    and you told SERIN you wanted up to 5 bytes (price\5\"#") as you should. However, when you went to WRITE the data, you didn't specify anything in your WRITE command, nor for that matter could you:
    The variable "price" is an array of single BYTES, of 5 in number. Why would you think that WRITE would presume to use more than one BYTE? Additionally "totalprice" (a rather odd name for a location index!) is never incremented, so you will only EVER WRITE into EEPROM location ZERO, and nowhere else.
    The following would work (just as a simple example) but it's very cumbersome and not sufficiently universal:
    WRITE totalprice,price(0), totalprice+1,price(1),totalprice+2,price(2),totalprice+3,price(3) ... etc.
    You will need to perform an iterative WRITE for the proper number of BYTES based on the size of the individual input received each time AND you need to increment the EEPROM location for each BYTE to be written. Also remember to clear your array to some unused characters each time, so you can locate the end of the individual (unknown length) input strings.
    Bruce Bates
    Post Edited (Bruce Bates) : 1/23/2007 12:52:10 PM GMT
  • UnsoundcodeUnsoundcode Posts: 1,532
    edited 2007-01-23 17:04
    Hi danlo, you are almost there, as Bruce pointed out the problem is that you are trying to write the whole array (price) into memory location 0 and what you need to be doing is writing one element at a time and indexing the memory location as you go. Here is an alternative solution using an index variable to iterate through the memory locations and the array.
    Totalprice DATA 0
    price VAR Byte(5)
    price_data VAR Byte
    index VAR Nib
    · 'SERIN 9,813, [noparse][[/noparse]STR price\5\"#"]
    ·· DEBUGIN STR price\5
    · DEBUG STR price,CR
    · FOR index =0 TO 4
    · WRITE totalprice+index,price(index)
    · NEXT
    · FOR index =0 TO 4
    · READ totalprice+index,price_data
    · DEBUG price_data
    · NEXT
    · READ Totalprice+2,price_data
    · DEBUG CR,price_data
    Jeff T.
  • danlodanlo Posts: 5
    Jeff.T
    thank you so much
