bs2 count program delay
Blake67
· Im using count to measure rpm but the whole program pauses as it is counting, Is there any way to use count without slowing the execution of the program?
Only if the detector and counter were off-board, meaning separate components.
Bruce Bates
<!--StartFragment -->
This guy sells a $12, simple 8-pin chip, which gives you a square wave you can use to synchronize your program. This may be exactly what you need. Read up on the "Simple Multi-Tasking" approach.
It also gives you one channel of buffered serial recieve -- but·the 'definite timed' multi-tasking is really useful.
