How many feet of wire possible using Full Dup object? — Parallax Forums
T ChapT Chap Posts: 4,224
edited 2007-01-23 11:44 in Propeller 1
With sheilded 2 cond cable with both Tx and Rx on one set, how many feet can you run reliably between 2 Props? I have extra pins on the Max 3232's, and need to run 50 feet. Anyone tried a similar distance without the drivers? Using the drivers will require some surgery but is doable.
  • AndreLAndreL Posts: 1,004
    edited 2007-01-23 10:06
    On the HYDRA there is a RJ11 home networking connector with some series resistors and some R/C noise / reflection passives on there and got my personal driver to 1.5 megabit at 300 feet with phone cable which isn't even twisted. But, I did run gnds on either side of the signals tx/rx. So bottom line is you should be able to go hundreds of feet with the right reflection cancellation at each end from the propeller.
    Andre'
  • T ChapT Chap Posts: 4,224
    Thanks Andre. I'll look around to see if I can see the circuit you are describing, that is good news.
