String --> Dec Conversion
Hey Everyone,
I'm using a PINK module for data entry to the Propeller.· The user will be entering data such as 4.032; this is of coarse stored in a PINK variable.· When the Propeller retrieves this data from the pink, it is in a string format.· How can I convert a string (like "4.032") to a usable decimal number (like 4.032)?· One idea I had on how to do this was to somehow seperate the string into one charecter strings (like "4" "." "0" "3" "2" ).· Then I think I could just subtract 48 from each charecter to get there decimal equiveilent.
Thanks in advance for your help,
crgwbr
NerdMaster
For
Life
crgwbr
NerdMaster
For
Life
NerdMaster
For
Life
Post Edited (crgwbr) : 1/22/2007 5:31:14 PM GMT
PUB rxDec : Value | place, ptr, x
·· Accepts and returns serial decimal values, such as "1234" as a number.
·· String must end in a carriage return (ASCII 13)
·· x:= Serial.rxDec···· ' accept string of digits for value
··· place := 1··········································
··· ptr := 0
··· value :=0············································
··· dataIn[noparse][[/noparse]ptr] := RX······
··· ptr++
··· repeat while DataIn[noparse][[/noparse]ptr-1] <> 13······················
······ dataIn[noparse][[/noparse]ptr] := RX····························
······ ptr++
··· if ptr > 2
····· repeat x from (ptr-2) to 1···························
······· if (dataIn[noparse][[/noparse]x] => ("0")) and (datain[noparse][[/noparse]x] =< ("9"))
········· value := value + ((DataIn[noparse][[/noparse]x]-"0") * place)······
········· place := place * 10······························
··· if (dataIn[noparse][[/noparse]0] => ("0")) and (datain[noparse][[/noparse]0] =< ("9"))
····· value := value + (DataIn[noparse][[/noparse]0]-48) * place
··· elseif dataIn[noparse][[/noparse]0] == "-"·································
········ value := value * -1
··· elseif dataIn[noparse][[/noparse]0] == "+"······························
I'll need to make it so that instead of CR (13) meaning the end of the string, it just accepts 5 digits (1.345).· Unfornuatly though I'm still very green in Spin.· Anyone have an Idea of where to start?
crgwbr
NerdMaster
For
Life
This would allow from 1 to a specified number of characters, essentially forcing a CR after the number of characters specified has been received.
I try to use the keyboard for setting time in the DS1307 demo Project coded by Beau Schwabe.
Seeing this post I tried to use the "extension to FullDuplexSerial " to convert for example 07 , typed from the keyboard·to use for setting the Year in the DS1307.
As a newbie I cant figure out how to pass this to the:
Extended_FDSerial.spin.....................
WHere should the string "06" be when calling the above routine?
Is it······ "06":= Serial.rxDec··,If so how to get the result?
For debugging and to se that it is ok I like to use the tv_text output to confirm.
OR is it a simplier approache to·pass the input from the·keyboard and place it in the following:
··· DS1307.SetBCDValue(07,Year_,0,99,$FF)·············· 'Set Year
Where it should be in BCD format i.e 07··
Any help would be welcome.
Regards, Goran
It seems to be a long way to go to Spin from pure asm!!
But I will not give up
I took the "PUB rxDec : Value | place, ptr, x ....."routine and past it in my DS1307 Object and it works fine so far. When I type 07 on the keyboard I got $07 on the TV screen.
Now, how to convert this to BCD format variable which I can place in the
······ DS1307.SetBCDValue(07,Year_,0,99,$FF)·············· 'Set Year
Any idea?
regards, Goran
As you can see, BCD just uses 4-bit "nibbles" to hold the digits. If, for some reason, you need a 4 digit BCD value in a 16 bit word, just do:
Now I can go on with my project, a board with a DS1307, a SD-Card and some sensors, all for long time logging of data.
The SD-Card works fine, now I can add the DS1307 to give me timestamps and the neccesary time for the Date & time when opening a file on the SD-card.
When done (no timeframe yet) If anyone intrested I can post the whole basic project (whithout the sensor part)
With this you should be able to set nessecary parameters from your keyboard, se what your doing on the TV-screen ,save it on the SD-Card and when done restart the propeller without the TV and keyboard, with correct time and parameters load from the SD-card and logg whatever to the another file (not the parameter file).
When done take the SD-card to a PC and evaluate the loggfile.
Regards/Goran
But I cant figure it out,
PRI·asciiToBcd(firstDigit,·secondDigit)
···return·(firstDigit·&·$F)·<<·4·|·(secondDigit·&·$F)
How to call this? and whats expected
I type 07 on the keyboard which is $37 or 7dec or ascii ▶
The result from:
is 0
Her is the code:
· y:= rxDec
· term.dec(y)·················· '=7
· term.out(y)·················· '=▶
asciiToBcd(y,z)················ 'tried asciiToBcd(z,y) and all possible variants
· term.dec(result)············· '=0
PRI asciiToBcd(firstDigit, secondDigit)
·· return (firstDigit & $F) << 4 | (secondDigit & $F)
Am·I stupid or? (getting late her)
Regards/Goran
If you want to start with a numeric value between 0 and 99 (instead of characters) do:
············· To:
repeat while DataIn[noparse][[/noparse]ptr-1] <> 0
I think this would work; any thoughts.· Again forgive me if I'm nowhere close, I'm not exactly sure what this line of code is doing, it's just the only line where I could find the number 13.
crgwbr
NerdMaster
For
Life
Guess I was tired yesteday night
I have it all OK now, ManyThanks, Goran
The change you're making should work. Are you sure the PINK strings end with a zero? I haven't looked at the documentation since the product came out. It may be so.
The REPEAT line (and the code around it) just copies the data to a buffer (called dataIn) and stops when a specific character is found (13 or 0 or whatever). The number of characters put into the buffer (ptr) is used to control the loop that actually converts the characters to a value.
NerdMaster
For
Life
