The ramifications of fuel level sensing
James Long
Ok....so I want to sense the fuel level in a tank.....
I would like suggestions to thoughts on how to do it accurately and safely.
The fuel is gasoline,·I don't want to instigate a flaming ball of destruction.
Ideas and thoughts????
James L
James L
Put some reed switches in a rigid plastic tube and inject the tube with silicon rubber,
then make a float that slides on the tube with a magnet on it.
The # of reed switches you use will determin the accuracy you get....
Bob
Not a bad idea....but silicon and gasoline do not mix. The silicon will degrade quickly....and end up in the fuel line.
Thanks for the idea....but I would like an easier approach.
James L
Jeff T.
A teflon/nylon tube would work,and gasket compound would work to pot the reed switches.
Even a brass or stainless tube would work if the magnet was strong enough.
Bob
James L
Jeff T.
EDIT
I have to relate this story, two guys at a place I worked were cleaning an open top vessel that used acetone as part of the process, they both got badly burnt when a static discharge from one guys clothes cause an explosion. Fortunately they both survived but after that our company went ground strap crazy.
Post Edited (Unsoundcode) : 1/21/2007 9:54:38 PM GMT
The reason I ask this. I know there are capacitance systems out there. I worked on an aircraft that used capacitance probes to read the fuel level. I know you can buy capacitance probes for you car's fuel tank.
I would think.....the most important part of the equation......make sure they are always wetted, and ensure the current and voltage is restricted as well.
James L
Jeff T.
Have you read the information on the website, "How Stuff Works"? Lots of great information there.
http://auto.howstuffworks.com/fuel-gauge1.htm
But I appreciate the help,
James L
Jeff T.
Neat.
thanks,
James L
