Writing/Reading via I2C to boot eeprom
Not having great success writing/reading to/from the Boot EEprom on a demo board - can some one show me an example ?
e.g a decimal value eg '1234' ?
Attached is a set of routines to do this with some comments on their use. You can also use the I2C object in the Propeller Object Exchange.
Trying to write a 4 digit decimal ('1234') to the end of the boot eeprom and read it back - thought it would be straight forward but I am having difficulty -I am using the Demo Board Rev C - loads of I2C routines out there but an example using the one you attached would be nice. I can see you are well up there on this aspect of things.
TE
You'll have to give more specific information about what you're trying to do if the above isn't enough.
All I want to do is write a value eg '1234' to Boot EEprom and recall it after a power cycle.
i.e without code -
i2c.i2cstart
i2c.I2cwrite(28,???)
waitcnt (500_000)
i2c.i2cread(28,???)
- assign the 'read in' value to an assigned var
To read it back in do:
This doesn't do any checking. You can follow the examples in the source comments for that. If you want to use a long instead of a word, just use a size of 4 instead of 2. I didn't write the routines to be used as an object. Just cut and paste them into your program.
Note: The kind of Start/Write/Read stuff you've hinted at in your posting won't work. Look at datasheets for EEPROMs to see the kinds of sequences needed. You have to write a device select code, then a 16 bit address, then some data. For reading, you have to write the select code and the address, then re-select the device for reading and read your data.
That worked perfectly - thank you ...
TE
The I2C specification (from Philips) requires pull-up resistors (about 4.7K) between each of the SCL and SDA pins and the +5V or +3.3V supply so that the signal lines are high if no devices are driving them so. Where there is only one possible bus master (like with the boot EEPROM on the Propeller), you can dispense with the SCL pull-up since only the Propeller will transmit a clock and can drive the line both low and high. You still need the pull-up on the SDA line to keep the line in a high state as the EEPROM and Propeller take turns transmitting data and there may be some overlap. If one of them drove the line high and low, there might be a brief short circuit that could damage one of them. By using a pull-up and only driving the line low, there can't be a short.
"i2c Object library v1.3 for the Propeller" only reads (no write) if does not have a resistance in SCL.
While the example works out great - when I power cycle I get an odd character back - If I write the value '1234' - when pin6 goes from low - high -low (010) it reads it back fine ... then after a power cycle it throws back an odd char - i believe chr 210...?
here is the sample -
VAR
word buffer
word old
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
obj
ee: "minimal_i2c_driver"
text: "vga_text"
Pub Main
buffer := 1234
text.start(16)
dira[noparse][[/noparse]0..7] := %0000000 'set p1 to p7 as inputs
old :=0
' set a pattern '010'on pin6 before write is called
' to ensure write is not called numerous times in the loop
repeat
if ina[noparse][[/noparse]6] ==0 and old ==1
old :=0
if ina[noparse][[/noparse]6] == 1 and old == 0
write
old :=1
else
read
pub write
ee.i2cWritepage(28,$A0,$7000,@buffer,2)
waitcnt(clkfreq / 200 + cnt)
text.out($00)
text.str(string("Wrote : "))
text.dec(buffer)
waitcnt(2_000)
pub read
ee.i2cReadPage(28, $A0, $7000, @buffer, 2)
text.out($00)
text.str(string("Read : "))
if buffer
text.dec(buffer)
Do be sure to clear "buffer" before reading it just to make sure it's read.
It may be that neither the write nor read is actually happening. Both
the i2cReadPage and i2cWritePage will return non-zero if an error
occurred and you could display a message if so.
