Prop. Pong
Here is a game I've been working on with the propellor called Propellor Pong. I used the Graphics_demo program as a framework. attached is the code for the game, which is regular pong. It runs on a TV, so hook up your demo board to a standard TV. Also, you need a mouse for playing. It is pretty hard, but you can win.(I have a few times). The trick is to get the ball going really fast.
Make sure you run this in the Propellor/Examples/Library folder(or any folder that has the TV, graphics, and mouse objects.
Tell me what you think of it,
ACfishing
ACfishing
Somebody said...
-Never Underestimate the power of human stupidity.
We really do need a repository of "demo board" games and things somewhere, ditto Hydra (although for that,
it comes with so many).
Congratulations! Keep on improving it!
Here is a variation you should find entertaining
plug a second mouse into the keyboard and play against another 'humon'
Perry
There are two different clocks like that on Makezine, my favorite is the watch.
Wall Clock:
www.makezine.com/blog/archive/2005/11/the_pong_clock.html
Watch:
www.makezine.com/blog/archive/2006/09/homemade_pong_watch.html
I would be cool to see someone make something similar with a Prop.
Lyle
A Propeller pong wall clock would probably be easier though. Projects have a way of growing larger than you originally intended; I think a Propeller watch could be done, but I'm not 100% sure it would really fit.
I am a real beginner in propeller programming. I am reading ton of stuff right now but I don't have a clue on how to convert the current code to work with a VGA screen.
Could anyone help me out?
2 points:
0. There is already a propeller based oled display https://www.littlepcbsolutions.com/uOLED-96-PROP.html
***edit*** It seems that this was discontinued a couple of years ago, but you still might be able to find one on the forum for sale if you ask.
1. It would be better to trim a protoboard as they are much cheaper. If you want to downsize a protoboard, Oldbitcollector has a guide to it http://www.warrantyvoid.us/tiki-index.php?page=Protoboard+Nano
