ezlcd002 display
Hi all,
Does anyone have any experience hooking up the prop to the ezlcd002 (an 001 with a touch screen)?
I have tried the color_selector_m.spin (for the ezlcd004) code, modifying the command constants to match the 002, but nothing seems to work. I have tried inverted/non-inverted mode (to see if that was it) to no avail.
I know the display is working because·I have a bs2 that controls it just fine.
When·I finally (out of frustration) just ran the color_selector_m code without modifying the command constants I (naturally)·got screwyness on the display. Which is what·I expected (at the most) since the command constants didn't match. But at least I knew then that the display would respond, albeit unfavorably.
To make things simple, the code I have running is the color_selector_m.spin modified to simply send a light_on command (with the correct value for a 002), but still nothing.
Has anyone out there tinkered with the ezlcd001 or 002?
Joe
Joe
I have not personally connected the 002 to a propeller, but I do have a 004 that I have been working with. I suggest you try the communication pins. I found they were backward from what I expected. I found this right away.....and I didn't have to ask anyone.
Also I know that if you disable some of the functions of the 002 (with the firmware) other things stop working. I read this on the EZ yahoo group and can't give specifics.....I didn't read that close.
Sorry I couldn't be more help,
James L
Don't ya love it when you figure it out yourself, but hate it when it was so right before your eyes to begin with?
I had done everything correct EXCEPT that I had inverted the RX pin not the TX pin.
What a dope I am. I wish I could blame it on something other than lack of attention to detail.
Anyway, thanks James.
Cheers
Joe
Glad you see you have it working.
Have fun,
James L
Other than that....it's extremely slick. I'll be posting my final project pictures when I'm done........I'm creating a product to sell, and it should be finished within two months.
James L
Have any one try the build in SD card reader?
