MHz and MIPS
stuartjmoore
I plan on using an SX chip to control a new project. Since timing is important, I was just wanted to make sure I was correct on a few things.
Does the MHz of the crystal used directly result in the MIPS performance?
and
Can I use any size MHz crystal on the Proto Board, not just 20, 50, and 75?
and
You may use any kind of crystal frequency on the proto board, or with the SX in general.
Greetings from Germany,
G
