Support for AX-12
Haven't found out by searching but are there libraries that support the new AX-12 actuator/servos from Dynamixel?
If not, would the UART VP be capable of somehow communicating with the AX-12 network which is half-duplex TTL (one line for both Tx and Rx)?
Here is the manual http://www.crustcrawler.com/products/bioloid/docs/AX-12.pdf
Thx
Thx
The manual talks about a dropdown line
so you must supply a pullup resistor.
The following should work
·················· +5V
················· [noparse][[/noparse]10k]
javPin o----[noparse][[/noparse]1k]----+
o device datapin
Initialize the uart for receive.
Send a command using
myUart.setDirection(Uart.dirTransmit);
myUart.sendByte(command);
//send parameter bytes
myUart.setDirection(Uart.dirReceive);
//receive response bytes
The only problem could be the time required to change from
sending to receiving (you could miss the first response byte).
If that appears to be the case, use the following
javTX o----[noparse][[/noparse]1k]--+-+
o device datapin
JavRX o
Note that in that case that anything you send is also received
(local echo) so you must remove the local echo bytes from
the receive buffer.
regards peter
Yves
