writing to sd card
I have a program that I'm working on the javelin with that uses gps. What I want to be able to do is record the gps coordinates to an sd card, so I can put it in my computer and then make use of that data.
So I need to know what hardware I would need to write to a memory card and then hopefully a few java examples if someone could.
Thanks...
Thanks...
http://www.sparkfun.com/commerce/product_info.php?products_id=7955
use the UART VP and away you go.
www.SDdatalogger.com
It's Only A Stupid Question If You Have Not Googled It First!!
I'm not sure about the code though. So if someone could write an example of reading and writing data to the card, it would be greatly appreciated.
http://chipdos.com/library/CD17B10_User_Guide_0v1.pdf
Code may look something like this:
//Program Listing - Logging bytes using SD DosOnChip
import stamp.core.*;
public class SDlog_demo {
final static int SERIAL_TX_PIN = CPU.pin0; // 2
final static int SERIAL_RTS_PIN = CPU.pin1; // 7
final static int SERIAL_CTS_PIN = CPU.pin2; // 8
final static int SERIAL_RX_PIN = CPU.pin3; // 3
static Uart txUart = new Uart( Uart.dirTransmit, SERIAL_TX_PIN, Uart.dontInvert,
SERIAL_RTS_PIN, Uart.dontInvert, Uart.speed19200,
Uart.stop1 );
static Uart rxUart = new Uart( Uart.dirReceive, SERIAL_RX_PIN, Uart.dontInvert,
SERIAL_CTS_PIN, Uart.dontInvert, Uart.speed19200,
Uart.stop1 );
static StringBuffer buffer = new StringBuffer(128);
static StringBuffer bufferLog = new StringBuffer("ABCDEFGHIJKLMNOPQRSTUVWXYZ");
static void bufferCmdMakeDir(){
buffer.clear();
buffer.append("md A:\\Logs\\\r");
static void bufferCmdOpenLog(){
buffer.clear();
buffer.append("ow #1 A:\\Logs\\log1.txt\r");
static void bufferCmdLogByte(char logChar){
buffer.clear();
buffer.append("w #1 ");
buffer.append(logChar);
buffer.append("\r");
public static void main(){
//set autobaud
txUart.sendString("\r\r");
//set Echo Off
txUart.sendString("e0\r");
bufferCmdMakeDir();
txUart.sendString(buffer.toString());
bufferCmdOpenLog();
int i = 0;
do{
bufferCmdLogByte(bufferLog.charAt(i));
i++ ;
} while(i < bufferLog.length());
//close file
txUart.sendString("q #1\r");
} // end main
} // end class declaration
Post Edited (yvesB) : 1/20/2007 5:37:26 PM GMT
I wasn't sure about what parts to hook up to pins.
I hooked it up as follows:
UART_RTS/BUSY to pin2
UART_CTS to pin1
UART_TX to pin0
UART_RX to pin3
VCC to 5v
GND to ground
I also changed the setting in the java program to match my setup:
final static int SERIAL_RTS_PIN = CPU.pin2;
final static int SERIAL_CTS_PIN = CPU.pin1;
I ran the program and then put the sd card in my laptop and couldn't find that any files had been written to the card.
Please help...
you find the connections and the baudrates
The allowable baud rates are:
• 1200
• 2400
• 9600
• 28800
• 38400
• 57600
• 115200
• 230400
so baudrate 19200 appears not to be an option. Use 9600 or 28800 instead.
regards peter
It seems that data is still not being written to the card.
Anybody have any ideas for an echo program that prints what comes back to the debugger?
final static int SERIAL_RTS_PIN = CPU.pin2; // 7
final static int SERIAL_CTS_PIN = CPU.pin1; // 8
SERIAL_RTS_PIN, Uart.dontInvert, Uart.speed9600,
Uart.stop1 );
SERIAL_CTS_PIN, Uart.dontInvert, Uart.speed9600,
Uart.stop1 );
public static void main() {
txUart.sendString("NULL");
// response
while (true) {
System.out.print((char)rxUart.receiveByte());
Nothing is returned... any ideas?
Try this echo without javelin handshake, that is, connect the device RTS pin to its CTS pin (local handshake).
Redefine your uarts without handshake pins.
Then try your echo test program again.
I could not locate the startup baudrate in the manual.
This could be different from 9600.
Edit: I just noted the autobaud feature, hence your double '\r' at the start of your
test program. The manual also states it sends out a prompt after baudrate has been set.
Have you set the mode0 and mode1 pins to select uart interface?
regards peter
Post Edited (Peter Verkaik) : 2/2/2007 9:36:24 AM GMT
http://chipdos.com/library/CD17Bxx-0v8.pdf
At the start of chapter 6 the mode pins are described
Both mode pins must be left open to select Uart interface.
Here is the schematic of the module
http://chipdos.com/library/DOSonCHIP-SD_Schematic_1v2.pdf
mode0 is at pin6 and mode1 is at pin7 of connector P1
VCC is at pin9 and is specified as 2.7-3.3V
regards peter
which has solder points SJ1 and SJ2 for Mode0 and Mode1.· These are left "open" so the device should already be in "UART" mode.
I believe that the sd module runs on something around 3v. If someone could tell me how I would get the right voltage from my board which puts out 5v that would be great.
Would I use resistors or what?
http://www.national.com/pf/LM/LM3940.html
regards peter
any ideas?
It depends how much current the device draws.
A javelin pin can only source 25mA.
regards peter
There are a few pieces of example code that are written for the basic stamp on thier website, but no javelin code.
So could someone help me with some examples to make this thing work with my javelin chip?
public class SDControl {
final static int SERIAL_PIN = CPU.pin4;
static Uart rxUart = new Uart( Uart.dirReceive, SERIAL_PIN, Uart.invert,
························ SERIAL_PIN,Uart.speed19200,
························ Uart.stop1 );
static Uart txUart = new Uart( Uart.dirTransmit, SERIAL_PIN, Uart.invert,
························ SERIAL_PIN, Uart.speed19200,
· txUart.sendByte('!');· // wake up
· txUart.sendByte('W');
· txUart.sendByte('U');
· txUart.sendByte('!');· // set pacing value
· txUart.sendByte('P');
· txUart.sendByte('V');
· txUart.sendByte(3);
· txUart.sendByte(0);
· //txUart.sendString("");
· // display response (if any)
· while (true) {
· System.out.print((char)rxUart.receiveByte());
I think it should return 30, but I doesn't.
There is some code written for this piece of hardware at www.sddatalogger.com
Any ideas on getting data written and read to an sd card with this?
txUart.sendByte(3);
txUart.sendByte(0);
To
txUart.sendByte(30);
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
static Uart rxUart = new Uart( Uart.dirReceive, SERIAL_PIN, Uart.invert,Uart.speed19200,Uart.stop1 );
· int c;
· rxUart.setDirection(Uart.dirTransmit);
· rxUart.sendByte('!');· // wake up
· rxUart.sendByte('W');
· rxUart.sendByte('U');
· rxUart.sendByte('!');· // set pacing value
· rxUart.sendByte('P');
· rxUart.sendByte('V');
· rxUart.sendByte(30);
· while (!rxUart.sendBufferEmpty()) ; //wait until transmit buffer empty
· rxUart.setDirection(Uart.dirReceive);
· while (true) {
· c = rxUart.receiveByte();
· System.out.println(c); //display data as integer values
regards peter
What I would like to do is be able to go through a loop and for each instance of the loop write a variable to DATA.TXT followed by a new line.
Then at a later time open that same file and for each line, put it into an array.
If you look at my other post: http://forums.parallax.com/forums/default.aspx?f=8&m=166896
You can see what I am trying to do.
I am trying to save the array that holds the pulses generated to a file on the card and then read and use them later to create those pulses again.
I hope that since peter has made this work out for me on both of my posts that he can see what I am trying to acomplish.
If you want to read your data from a PC, then use the STRING format "!AS" to append and "!RS" to read. For STRING format all values must be converted to ASCII before writing, and value read back must be converted from ASCII. But your data will be readable from most any PC application. STRING data is always terminated with the string termination character (usually a linefeed because PC strings end with carriage-return and linefeed). STRING data can be variable length, but cannot be read randomly. In other words if you want the 20th string, you must read past the first 19 to get to it.
STRING commands:
!ST - Sets the string terminator character
!AS - Appends a string to the end of a file
!RS - Reads a string from a file
If you want to read and write from the microcontroller, then use the RAW format. Here data is stored in the normal binary format that the microcontroller uses. No conversion is require. BUT a PC application will most likely NOT be able to read the data. RAW data is fixed in size, but CAN be read randomly. If you want the 20th record you can just seek it and read it.
RAW commands:
!AR - Append record
!RR - Read record
!GP - Goto file position
I hope this helps,
Bean
The Format class can easily convert binary data to ascii and vice versa.
char[noparse]/noparse buf = new char[noparse][[/noparse]9]; //holds sign + 5 decimals + CR + LF + closing null
int value = 1756;
Format.sprintf(buf,"%6d\r\n",value); //convert binary to ascii (8 bytes + null)
tx.sendByte('!');
tx.sendByte('A');
tx.sendByte('S');
int i = 0;
while (buf[noparse][[/noparse]i]!=0) tx.sendByte(buf[noparse][[/noparse]i++]); //send string
The above example sends "· 1756",CR,LF
To read a string
tx.sendByte('!');
tx.sendByte('R');
tx.sendByte('S');
int len = rx.receiveByte(); //get length (includes termination character)
for (i=0; i<len; i++) buf[noparse][[/noparse]i] = (char)rx.receiveByte(); //read string charracters
buf[noparse][[/noparse]i]=0; //make asciiz
len = rx.receiveByte(); get errorcode
int[noparse]/noparse newvalue = new int[noparse][[/noparse]1]; //placeholder for binary value
Format.sscanf(buf,"%d",newvalue); //convert ascii to binary
If the string was "· 1756",CR,LF then now newvalue = 1756
regards peter
Here is what I have now, but when I put the card in my laptop, I'm still not seeing any files on it.
I believe I should see a DATA.TXT with 1756 in it, but I dont.
import stamp.util.text.*;
final static int SERIAL_PIN = CPU.pin15;
int c;
rxUart.sendByte('!'); // wake up
rxUart.sendByte('!'); // set pacing value
CPU.delay(2000);
rxUart.sendByte('!'); // attempt to close file
rxUart.sendByte('C');
rxUart.sendByte('F');
CPU.delay(2000);
rxUart.sendByte('!'); // attempt to open DATA.TXT
rxUart.sendByte('O');
CPU.delay(30);
rxUart.sendByte('D');
rxUart.sendByte('A');
rxUart.sendByte('T');
rxUart.sendByte('.');
rxUart.sendByte('X');
CPU.delay(2000);
int value = 1756;
rxUart.sendByte('S');
int i = 0;
while (buf!=0) rxUart.sendByte(buf[noparse][[/noparse]i++]); //send string
while (true) {
int c;
c = rxUart.receiveByte(); //get returned pacing
if (c != 30) { //returned value invalid
· System.out.println("pacing set unsuccesful");
· while (true) ; //halt program
CPU.delay(2000);
c = rxUart.receiveByte(); //get error code
CPU.delay(2000);
rxUart.sendString("!OFDATA.TXT"); // attempt to open DATA.TXT
if (c!=0) {
· System.out.println("file not opened");
CPU.delay(2000);
int value = 1756;
int i = 0;
while (buf[noparse][[/noparse]i]!=0) rxUart.sendByte(buf[noparse][[/noparse]i++]); //send string
if (c!=0) {
· Format.printf("appending string failed, errorcode %d\n",c);
CPU.delay(2000);
Format.printf("closed file, errorcode %d\n",c);
