Yes, I'm using the xBee with one of Martin Hebel's adapters (at www.selmaware.com). Since the xBee is a 3.3V device, you don't really need the adapter, but it makes connecting things easier. I happen to have gotten one of the USB adapters as well and used that to set up the device (with network IDs, etc.) using Maxstream's setup program. It looks just like a serial port to the Propeller and I use the FullDuplexSerial object as the I/O driver.
Sid
Sid Weaver
Don't have VGA?
Newzed@aol.com
Thanks. I was thinking more in line with embedding the zigbee stack into the propeller chip.
