Minor SX-Key Bug
I'm running the SX-Key v3.2 on XP Pro SP2 and I found a minor bug. It seems that accidentally declaring a variable twice causes the program to crash. For example I had this code:
and the repetition of temp caused the SX-Key program to crash. I don't know if this was already known but I just wanted to make sure you guys were aware of the bug.
-Amit
temp var byte 'A2D 2 Variables A2D2 var byte(7) BStrainR var A2D2(0) VStrain1 var A2D2(1) HStrain2 var A2D2(2) temp var A2D2(3) VStrain2 var A2D2(4) HStrain1 var A2D2(5) BstrainL var A2D2(6)
-Amit
What version of the SX/B compiler are you using ?
I tried it on 1.51.03 (the latest release) and I get "DUPLICATE VARIABLE NAME" error on the 2nd "temp" defination.
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
