Thru Hole Pins?
SailerMan
There was a thread I read where someone mentions little pins or collars or what ever they are called that can be placed in a Home Made PCB to create a thru-hole.
Does anyone remember this thread or know what I'm talking about.
Eric
Eric
Jeff T.
Thanks again,
Eric
Maybe better to just solder a "jumper" pin between the traces on the two sides?· Or, to make it fancy: the legendary 0-ohm "resistor"?
Post Edited (PJ Allen) : 1/16/2007 1:49:15 AM GMT
Great results, but...
Bl**dy fiddly job!
After that I swore to only use component-legs for through-hole, and to avoid double-sided PCBs when they're not necessary.
Saves a lot of swearing...
Don't visit my new website...
Just out of curiosity, and since I've never fooled with eyelets, is the difficulty that they're two piece units which must be lined up, or is the difficukty in the one-sided swaging process? I suppose it might be that they are simply tubuler with expanded ends, and may need to be swaged on both side which would be a major pain!
Thanks for the insight without the hair pulling
Bruce Bates
<!--StartFragment -->
You pushed the other end through the hole in the PCB, placed the pcb and eyelet on the die and pulled down on a handle. This brought the other part of the die down and expanded the other end.
It worked, but it was time-consuming and fiddly.
And if you didn't push hard enough, you might end up with a weak connection that might deteriorate over the years...
I would think that there would be a setup that could control this better, but the cost of such a press might make farming the boards out seem cheap.
If you only have a few vias, it's not bad, but then neither is using component pins and/or the 0 Ohm via resistor (wire) and soldering both sides.
If you have lots of vias, it can make for a long afternoon.
John R.
8 + 8 = 10
