FullDuplexSerial Locks Propeller
I tried searching (with the google tool) and couldn't find this, so my appologies if it has been covered. (I am not a "search master", but I try.)
I'm doing some testing with the FullDuplexSerial object for Popeller/PC communicaiton on pins 31/30.
It works fine (at least sending from the prop to the PC), except:
If I start the object without hyperterm connected, all is fine.
When I connect hyperterm, I start getting the data I expect.
If I disconnect hyperterm, the prop appears to lock up. If I try and re-connect hyperterm, things still sayed locked up.
I didn't see any "time out" features avaialable for the xmit functions.
Am I missing something?
I've basically started adding a few things to Jon W's Servo32_Demo program. I have two servos "panning", and one of the reasons I say the prop locks, is that in addition to the data stopping (obviously), the data also stops going to the LCD, as well as the servos stop.
Here's the code:
Now in my case, this is kind of like when you tell the doctor "It hurts when I drop a rock on my foot", and she replies "Don't drop a rock on your foot." I can obviously keep the port on the PC open, at least for now, but I would like the ability to open and close communications in the future, and also deal with a "lost" communication without the prop locking.
Other than some minor playing around with the Prop Education Kit, this is my first real work with the Propeller, so I may be doing something totally bone headed.
Thanks for any help and suggestions.
(I'll also take any hints on other areas of "sloppy" code, this is just "hacked" together to see how things work.)
John R.
8 + 8 = 10
Post Edited (John R.) : 1/14/2007 2:14:30 AM GMT
Here's the code:
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000 'Note Clock Speed for your setup!!
PanServo3 = 7 'For DEMO only Set servo on pin7
'; could be any pin
PanServo4 = 8 'For DEMO only Set servo on pin8
'; could be any pin
OBJ
SERVO : "Servo32"
LCD : "Serial_Lcd"
SN : "Simple_Numbers"
FD: "FullDuplexSerial"
VAR
Byte bPanCount
PUB Main | temp
'Preset Servo's you want to use to center position
SERVO.Set(PanServo3,1500)
SERVO.Set(PanServo4,1500)
'Note: Servo pins that will be used must be preset before running "SERVO.Start".
' This is because the I/O direction is set here and is only executed
' at the beginning of "SERVO.Start". Servo pins that aren't used will remain
' in their original direction state.
SERVO.Start 'Start Servo handler
LCD.Start(16, 9600, 2)
LCD.Str(string("This is a test"))
bPanCount := 0
FD.Start(31, 30, 0, 9600)
repeat
'Pan selected DEMO servo3 & 4
'back-n-forth opposite of each other
repeat temp from 1000 to 2000
waitcnt (cnt+125_000)
SERVO.Set(PanServo3,temp)
SERVO.Set(PanServo4,3000-temp)
repeat temp from 2000 to 1000
bPanCount += 1
LCD.cls
LCD.Str(SN.DEC(bPanCount))
FD.Dec(bPanCount)
John R.
8 + 8 = 10
-Martin
Martin Hebel
StampPlot - Graphical Data Acquisition and Control
AppBee -·2.4GHz Wireless Adapters & transceivers·for the BASIC Stamp & Other controllers·
While using f11 might get me going again, the reset would not be desireable "in the real application".
I assume that moving the USB2SER off the Programming ports (and/or building in a way to break the "RESET" connection in "run mode") would also fix this, correct?
And thanks for the very fast responses!
John R.
8 + 8 = 10
I've got a home built demo board, and on my setup I've got a switch on RSTn (Program/Run) this way after I download a program I switch to RUN then I can open a communications program like ProComm ot HyperTerm with out resetting the Propeller. If you can find a way to disable the DTR pin on your cable that would work too.
Thanks again guys, and have a great evening (or whatever time you're living in).
John R.
8 + 8 = 10
I'll have to find a way to break the reset connection as required for a more permanent solution.
Thanks again for the quick help.
John R.
8 + 8 = 10
