Larger eeprom or fram on prop
What would happen if you put a 512K eeprom on the prop?· Could you address 257-512 without affecting the bootup?· What would happen with one of the new (at least in the mouser catalog) fram chips.· (Across the page from the microchip eeproms)
FRAM's should work fine, they better, I have five I just received - however I need to surface mount them on some adapters, the ones I got were SOIC (dip's were not available)
www.mikronauts.com - a new blog about microcontrollers
