receiving long instead of a byte
I think this likely a basic question, but one I have yet to figure out. I have applicatio that i wrote wich controls a stepper motor via serial comands. I'm sending the number of steps for the motor to turn from a visual basic brogram I have writen but I only know how to send an array of bytes or a string through the serial port which is limiting the number of steps to 0-255. Is there a way to send a larger number? I need the propeller to see a number as large as 180,000. is there a way to send 4 seperate bytes and have the propeller create a long from them?
here is the current code i'm writing Is attached if it helps.
thanks,
Owen
thanks,
Owen
byte b0,b1,b2,b3
b0:=serin
b1:=serin
b2:=serin
b3:=serin
pos[noparse][[/noparse]0]:=b0
pos:=b1
pos:=b2
pos:=b3
byte b0,b1,b2,b3
b0:=serin
b1:=serin
b2:=serin
b3:=serin
pos:=(b0<<24) and (b1<<16) and (b2<<8) and b3
pos:=(serin<<24) and (serin<<16) and (serin<<8) and serin
thank you!
The Propeller receives the two bytes, the ID then the position, and converts the ascii string to a 32 bit integer. After each set is rec'd, a case statement compares the ID to a list, if it is X then a variable X is updated, same for Y, Z, R. Another cog sends the motor to any newly arrived position.
CON _clkmode = xtal1 + pll16x ' use crystal x 16 _xinfreq = 5_000_000 ' 5 MHz cyrstal (sys clock = 80 MHz) TAB = $09 CR = $0D VAR byte array[noparse][[/noparse]24] ' buffer for numeric fields long X, Y, Z, R ' these are actually 32 bit integers long temp1, temp2 OBJ ser : "fullduplexserial" term : "tv_terminal" PUB Start | i ser.start(0, 1, 0, 9600) 'rec tx mode baud term.start(12) 'enable TV terminal repeat if receiveStr(@array,24) <> TAB term.str(string("Missing TAB after temp1",CR)) quit Temp1 := convertstr(@array) if receiveStr(@array,24) <> CR term.str(string("Missing CR after temp2",CR)) quit Temp2 := convertStr(@array) CaseTemp PRI receiveStr(address,count) | c repeat count 'start counting c := ser.rx 'c = first rec'd byte if c == TAB or c == CR 'c == CR or TAB, byte[noparse][[/noparse]address] := 0 return c 'now return delimiter for optional checking byte[noparse][[/noparse]address++] := c 'update c return 0 'default delimiter is zero PRI getrx recbyte := ser.rx PRI getarray | i repeat i from 0 to 4 if recbyte == $0D recbyte := 0 PRI convertStr(address) | C repeat while c := byte[noparse][[/noparse]address++] result := result * 10 + (c - "0") PRI CaseTemp case temp1 4270 : x := temp2 '4270 is decimal equiv to ascii string "XID" , if it is X, then the vairable X is written to the value rec'd repeat until not lockset(SemId) RetEcheck(string("XID"), X) 'return the value back to the app to verify prior to motor run lockclr(SemId) case temp1 4370 : y := temp2 repeat until not lockset(SemId) RetEcheck(string("YID"), Y) lockclr(SemId) case temp1 4470 : z := temp2 repeat until not lockset(SemId) RetEcheck(string("ZID"), Z) lockclr(SemId) case temp1 3670 : r := temp2 repeat until not lockset(SemId) RetEcheck(string("RID"), R) lockclr(SemId)Post Edited (originator) : 1/14/2007 8:54:01 AM GMT
