Driving Multiple LEDs from a transistor
Zoot
I want to drive 4 or 5 LEDs (@ ~17ma each) from a transistor.
I wired up one LED to a transistor and a micro pin following the attached schematic (which has been reproduced many places in these forums).
So... if I wanted to hook up several LEDs, can I tie the cathode of all of them to the transistor and the anode of each to Vdd through it's own limiting resistor? Or would I need a transistor for each (I would think not, since the 2N3904s I have on hand should be able to handle up to 100ma).
Magic Smoke Theory of Electronics –
Inside every electronic part there is magic smoke.
The magic smoke is what makes everything work.
If you release the magic smoke, the part stops working!
It okay to parallel them if each LED has it's own dropping resistor.
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
