New Sensor Suggestion/Request.
Hi this question is really for anyone from paralax.
Is there any plans to offer a small laser rangefinder, if at all possible. It would be a great upgrade from the ping. Just a small simple single laser to return a distance, that can be mounted on a servo just like the ping. This would be a great way to get around problems with the ping. Especially the issue that when you are trying to get a distance with the ping to an object that is set at an angle to the ping sensor you always get longer returns. A laser would take care of this. Would love a miniature Sick Laser Range Finder but i think that probably a little much.
Has anyone else been able to integrate a laser rangefinder onto the Boe and what did you use.
Thanks All
Thanks All
Im pretty sure construction companies have some handheld version of this to measure the height of buildings but im not sure.
Also, a laser range-finder operates at the speed of light (as I recall). That's like 12" per nanosecond (rule of thumb thanks to Grace Hopper.). So in one micro-second it would go 1000 feet. You'd need an on-module processor to read the distance, then send some signal the BS2 could use, because the BS2 doesn't have the timing resolution to read that signal.
John R.
8 + 8 = 10
I just don't where to look to find a cheap single laser rangefinder that could be compatible.
They have laser rangefinders in gun scopes, a very low end model like that should work, I just don't know how to interface it.
http://www.ibeo-as.com/english/technology.asp
For an article describing use:
acroname.com/robotics/info/articles/laser/laser.html
To buy:
acroname.com/robotics/parts/R283-HOKUYO-LASER1.html
kelvin
When you see the pretty smoke come from a component. It is time to go shopping again.
Problems are the "roads" of life,
solutions are only "onramps" to the next problem
············································· "Brad Smith"
If you place the laser and the receiver close together you can get by with a small receiver, but will get lousy resolution and horrible accuracy over distance.
If you place the laser and receiver well apart you'll need a larger-surfaced receiver, but will get better accuracy over distance.
Something like these might be useful as receivers:
http://www.sales.hamamatsu.com/en/products/solid-state-division/image-sensors/photodiode-array-with-amplifier/s8865-128.php
Edit:
Found a bunch of them at Mouser:
http://www.mouser.com/search/Refine.aspx?Msb=0&Mkw=linear&Ntk=Mouser_Wildcards&Ne=1491393+1447464&Ntx=mode+matchall&Ns=P_SField&Ntt=*linear*&N=1323038%201491393
Some of them are even affordable...
Don't visit my new website...
Post Edited (Gadgetman) : 1/16/2007 9:54:07 AM GMT
sry pal
-peace Henry
The cheap ones(less than $150 or so) models are all ultrasonics, and the laser beam is just an aiming tool.
A $2500 one may sound a bit expensive, but what kind of acuracy does it have?
And what kind of casing?
(An IP67, dust and waterproof enclosure is expensive, and if you want shock-absorption, that'll also cost you)
Does it interface with other types of equipment?
(Some can be mounted on a tripod, then set to rotate and tilt up and down, to scan the entire area, so that you can download a complete 3D map from it later)
Some of the guys at the office walk around with $5000 GPS units.
And they wanted an even more expensive model...
