sx28 output voltage on ports compared to supply voltage
loser
hi
i was wondering is the output voltage on the sx28's ports relative to the supply voltage given to the chip itself?
the sx28 datasheet shows that the chip can be powered with 3v - 5.5V (@ 50MHz)
so if i power my chip with 3.3V, will it output ~3.3V on the ports when sending a high signal?
(i am setting up my ports·as TTL)
thx
loser
thx
loser
Yep you got it right. If you operate the chip from 3.3V then when a pin is high it will output 3.3V.
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
thx for the quick reply
