Assembly Woes
I've made some good head way making an assembly object, but I'm stumbed over how to call in assembly a cognew and pass a PARemeter.
I can call assembly from spin just fine and I am handling arrays OK. I would like to now be able to pass a new cog an array from assembly.
Or is that a NO NO. The manuel shows the upper bits of the destination as the parameter but using the double @ with the call I'm getting confused!
pub main cognew(dothis,@dothat) dat
dothis org
mov t1,par
cognew @@T1
t1 res 1
dothat org
something else
t1 with the new PAR
t2 with the address to be loaded
SHL t1, #16 'replace t1 with the register that has the new PAR to be given
SHL t2, #2 'address to start loading from in main ram
OR t1, t2
OR t1, #8 'for cognew bit
COGINIT t1
that is how it comes across to me
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
Post Edited (CJ) : 1/10/2007 2:40:37 PM GMT
So if I understand you right the:
If set to less than #8 would be a coginit:
For instance would start/restart cog 3?
And the line:
Would be what I normally pass with the offset double@?
And obviously the Par is the array!
I am not quite sure on the use of @@ though
In the code I posted below the spin passes the address of the start of the object, the recieving cog adds it to the offset of the address of the cog I wish to start, and it works!
The questions are this: Say I want to pass an array buffer to the cogs.··············The first ones par is tied up with passing the base address. So, knowing how to code the par in the second coginit from assembly isn't going to help me much if I don't know the address. Is this just poor programming or is there a trick here I'm not seeing?
By declaring my array in assembly I can get it's address and just set a var in spin equal to it.
The one thing that still puzzles me though,
·If you call a routine and pass a variable in par, WHERE then is the stack space for the new cog you just called from spin?
If you're starting an assembly routine, you don't need a stack. You only need "cognew(@someRoutine,@parameter)"
I can stop chaseing my tale about that now.
I'm going to try declaring my array in assembly and see if I can't get up to speed with Three cogs. So far my SPI is blazing with two cogs, I'm hopeing to do some data validation in a third without slowing the first two down.
Paul Baker
Actually No. I've been more interested in just getting a few things to work using longs. No doubt I'm wasting a lot of ram at this point as my data is only 12 bits(from a max 1270 converter), The application will not need much program space as it is a data in, data out type application. So longs are fine for now.· I do intend to practice that, I just wanted to get a working app together as quick as I could to make sure my hardware was going to support it, then build a demo and optimize the code from there.
Plus speed is a concern, so processing longs is keeping my up to par with the sample rate of the converter. I thought maybe latter I would use the upper word to keep cnt difference information to keep track of any jitters in my sample rate, but waste is OK for now.
