Toddler with a PSC
Well, for my first post, I need to express my frustration at trying to integrate the PSC with my Toddler.· This combination seemed like it would be a good way to offload some processing, but so far it has just given me a headache.· I think my first mistake was to ignore this line in the PSC·manual:
I·assume that since the standard setup for the Toddler powers two servos, that the addition of the PSC would be trivial, so I attempted to power the PSC from the Vin·terminal on the toddler PCB (6 V).· With this configuration·(and the three conductor cable connected to Vdd, Vss & Pin 5), I could ONLY run the version and baud rate sample programs successfully with the PSC switch in the OFF position.· When I turn the PSC switch ON the PSC no longer reponds, though the green LED does continue to indicate communication is taking place.
Is my problem really the power source?· I really didn't want to add another 4 batteries to my toddler.· There's not alot of real-estate there, given that it has to balance itself.
Any advice would be appreciated.
The power source for the servos must be a separate power source from that of the Board of Education Rev C.
I.e., which connector(s) on the Toddler board did you connect with which pins on the PSC board, in order to power the servos? (You stated, "Vin" of the Toddler, but what about the ground also?)
My question begs the issue of "power source for the servos must be a separate power source from that of the Board of Education Rev C." Parallax may have specific reasons (e.g., exposure to voltage drops, noise, power capacity limitations?) why the sources must be "separate".
PAR
Once the servos are powered on, the PSC seem to ignore all serial commands.
If it doesn't work then either, it suggests that it's not the source(s) of power as the problem.
PAR
I would connect the PSC as follows and see if you get better results:
- Vin (if not higher than 6v) or Vdd to the V+ terminal on the PSC (terminal block)
- gnd to the V- terminal on the PSC (terminal block)
- Vdd to the +5v header (servo header)
- Stamp pin to the signal header (servo header)
- do NOT connect logic ground (Vss) to the servo header
Sorry. I probably should have written "possibly".
Luke
The perversity of nature is nowhere better demonstrated by the fact that, when
exposed to the same atmosphere, bread becomes hard while crackers become soft.
Luke
I am fairly certain that my problem is basically a lack of current.· I will be experimenting with other configurations, and will report back my findings in this thread.· Thanks to all those that posted suggestions!
