Pin sockets used for oscillator on sx48 proto board
I'm sourcing parts for a PCB and I was wondering if any one knew of a good source for the pin sockets used for the TTL oscillator on the sx48 protoboard.
I need to have the oscillator socketed in this version of the board so I can remove it when programing it.
I would use a removable jumper to protect the osc1 pin, but I'm running the oscillator at 80Mhz and I'm trying to keep the signal clean. I'm open to any ideas if anyone has any.
In a future version of the board I want to implement it through a transistor so I can do field updates to the board using the 8051 which present in the usb 2.0 chip.
-Ben
http://www.allelectronics.com/cgi-bin/item/SIP-40/search/40_PIN_MACHINE_CONTACT_SIP_SOCKET_.html
http://www.mouser.com/search/ProductDetail.aspx?R=1-1571994-0virtualkey57100000virtualkey571-1-1571994-0
http://catalog.tycoelectronics.com/TE/bin/TE.Connect?C=1&M=BYPN&PID=119780&PN=510-AG91D-10&I=13
Let me clarify.
These are the pin sockets that are used for the TTL OSC which is configured in a DIP-8 on the protoboards. I had used a dip 8 socket in the last rev of the board, but the sockets used in the protoboard look a lot cleaner and more professional.
Thank you!
http://us.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=4392&Row=331913&Site=US
