Request for an improvement on the chip
Although I know you are all very busy with improving and expanding the core of the propeller, I have a simple request
Could you possibly add another 'mode' on the hub ring encoder? It wouldn't require that much more logic, and it would
improve performance on non-deterministic hub operations.
Have two modes, Deterministic and quazi-fifo. Deterministic would only allow that cog to access the hub when the
ring is at it's index like it does now. quazi-fifo would allow a cog to perform hub operations if the hub is otherwise
indisposed, prioritized by it's index and the location of the ring buffer.
IE:
If the ring is at position 1... Do deterministic op for cog 1 if it wants it, otherwise, do 2, then 3, then 4 .. 8
If the ring is at position 2... Do deterministic op for cog 2 if it wants it, otherwise, do 3, then 4, then 5 .. 8, then 1
etc.
I only really suggest this for things like interpreted code where hub accesses are almost constant, and when performing
non-timing sensitive code where speed would be helpful (like decompression and external storage routines)
IE:
etc.
the hub controller to allow more than one access per cycle to a given cog. It would still be deterministic, but would
allow higher throughput for those cases you mentioned. I don't remember whether there were any conclusions.
The main advantage was that it was implementable reasonably in hardware and was still deterministic.
I just threw this in as a system that wouldn't cause any compatibility problems (since a cog doesn't have to access on 'off cycles')
