Stamp talking to transmitter via trainer port
Does anyone has experience in using Stamp module to generate pulse and send·the signal·via a Futaba transmitter thru trainer port connection? The trainer port is·of a·DIN 6-pin configuration. How should the stamp and trainer port be connected? All ideas are welcomed and appreciated.
Thanks in advance!!
kevin
Thanks in advance!!
kevin
I don't have the Futaba docs ( which is what you need to Google first) in front of me but I expect its one of two possibilities:
1. the DIN plug will accept standard servo pulses ( 1mSec - 2mSec) which the stamp can replicate quite well.
2. the DIN plug takes resistive pot signals from a set of auxilary joysticks.
Keep us informed of your progress. This will probably be of interest to several folks here.
Tom Sisk
http://www.siskconsult.com
I'm not certain what voltage levels this port uses, or expects, so that could be a problem. The easiest way to discover this would be to put a logic analyzer on the data pin, and record what's going on in real use.
I'm not sure what this would achieve. I mean, you'll have an "open loop" control (no feedback) of whatever your target (airplane, car, whatever) is. I believe the 'trainer port' does get the generated pulse train BEFORE it's RF-encoded, so that may make this do-able.
