how does I2Cobj work when handeling a ds1624
Hello people,
I am new to I2C with the propeller chip.
Now I want to read the temp of the ds1624(which is different than the ds1620).
The commandos have to be:
Start
%10010000
$AC
$00
Stop
Start
%10010000
$EE
Stop
Start
%10010000
$AA
Start
%10010001
RX··············· <receive temp reading 2 bytes long
Stop
There are ofcourse ACK after every byte that is send and·NACK after every byte that is received
How do I handle the I2Cobj.spin because I don't get it really.
I want to keep it as simple as those commando's, and no extra's like checking if there an error.
Best regards,
Bart Veenstra
Start
%10010000
$AC
$00
Stop
Start
%10010000
$EE
Stop
Start
%10010000
$AA
Start
%10010001
Stop
Best regards,
Bart Veenstra
James
PUB i2cStop
PUB i2cStart
PUB i2cWrite(i2cData, i2cBits) : ackbit
PUB i2cRead(ackbit) : i2cData
But I dont know how to use it.
Should my code be like below
i2cObject.i2cStart
i2cObject.i2cWrite(%10010000, 8)
i2cObject.i2cWrite($AC, 8)
i2cObject.i2cWrite($00, 8)
i2cObject.i2cStop
if I want to send:
Start
%10010000
$AC
$00
Stop
to adres 4 for example.
Maybe some one help me a little bit, don't need much help.
You need to read the product datasheet, you seem to be missing some·steps from the communication.
The manual is here http://datasheets.maxim-ic.com/en/ds/DS1624.pdf
You really need to look at the DS1621 example as, from a brief look at the ds1624 datasheet, the two products protocols·should be nearly identitical.
James
~~Brian
con _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 deviceaddress = %10010000 obj i2c : "i2cobject" pub start (sda, scl) i2c.start i2c.init(sda, scl, FALSE) 'leave at false if you have pull-up resistors, switch to TRUE to drive pins from prop (not reccomended) pub command1 : success 'sends first command success := i2c.writelocation (deviceaddress, $AC, $00, 8, 8) 'sends device's address, then the register, then the data. 8 address bits, 8 data bits 'saves acknowledge bit from device to "success" return success pub command 2 : success success := i2c.writelocation(deviceaddress, $EE, "command here", 8, 8) return success pub command2_alt 'use if no data is to be sent to $EE i2c.i2cstart 'starts i2c i2c.i2cwrite (deviceaddress, 8) 'sends device address i2c.i2cwrite ($EE, 8) 'sends register address i2c.i2cstop 'stops i2c pub read1 : readdata readdata := i2c.readlocation (deviceaddress, $AA, 8, 16) 'reads 2 bytes from register $AA (8 address bits, 2 bytes at 8 bits each = 16 data bits) return readdatatry that. make sure you have pullups on your data and clock lines. it needs i2cobject.spin to be in the same folder (obviously).
good luck!
Start,%10010000,ACK,$AC,ACK,$00,ACK,Stop <==configuration register. 1shot
Start,%10010000,ACK,$EE,ACK,Stop <==Start convert.
Start,%10010000,ACK,$AA,ACK,Start,%10010001,ACK,Receivebyte,ACK,Receivebyte,NACK,Stop <==get 2 byte data
the last ACK and NACK must send from master to slave.
The ds1624 is connected to the prop with 2x 4k6 pull-up and 100Ohm resistor in serie to the prop output 28(SCL),29(SDA), the eeprom is also connected there for the propsoftware.
con
obj
i2c : "i2cobject"
i2c.start
pub Config : success························································· 'sends first command
success := i2c.writelocation (deviceaddress, $AC, $00, 8, 8)·····'sends device's address, then the register, then the data. 8 address bits, 8 data bits
return success
pub Convert····································································· 'use if no data is to be sent to $EE
i2c.i2cstart······································································ 'starts i2c
i2c.i2cwrite (deviceaddress, 8)············································· 'sends device address
i2c.i2cwrite ($EE, 8)··························································· 'sends convert prot.
i2c.i2cstop········································································'stops i2c
readdata := i2c.readlocation (deviceaddress, $AA, 8, 16)······· ··'reads 2 bytes from register $AA (8 address bits, 2 bytes at 8 bits each = 16 data bits)
return readdata
Post Edited (darkxceed) : 1/10/2007 7:05:58 AM GMT
But I don't know how to get the second byte of·temperatuur.
This byte contains the precision values lower than 1degree.
pub·read1·:·readdata
··readdata·:=·i2c.readlocation·(deviceaddress,·$AA,·8,·16)·········'reads·2·bytes·from·register·$AA·(8·address·bits,·2·bytes·at·8·bits·each·=·16·data·bits)
··return·readdata
In the upper syntax I set it to 16 to read 2 bytes but the second byte stays %00000000
If I have the second byte I than can manipulate is because only the last 5 bits contains a·measure value.
In total the tempreading is 13bits long.
If I try it in low level code I maybe understand it more.
