74HC595 and lcd screen.
Vitor
Can the 74HC595 be used to drive the Hitachi LCD screen (the one that comes with the stampworks kit)? Or, do I need to get a serial LCD screen?
If it can be done, do you know where I can find a sample circuit and code?
Thank you.
Thank you.
A 3 wire inteface using a 74HC595 is shown in Nuts & Volts #32 here www.parallax.com/dl/docs/cols/nv/vol1/col/nv32.pdf
This is what I generally use:
http://www.allelectronics.com/cgi-bin/item/EDE-702/search/LCD_CONTROLLER_IC_.html
and they work real well with most character based LCD's which are Hitachi HD-44780 compatible.
Bruce Bates
<!--StartFragment -->
