sxkey Vdd current?
Does anybody know how much current the sxkey rev.F draws when
programming and when not programming but just connected to a board?
Makes it any difference if there is a 20MHz resonator fixed on the board?
The board has a sx18ac/dp chip.
regards peter
regards peter
The SX-Key should work if there is a resonator. The resonator itself will not draw any power.
Alex.
Fear not that your project does not work, for it will,
Fear not if you see·a long dark path ahead, but follow it,
Fear not if what worked now refuses to,
For the only thing that's perfect is imperfection.
