three questions on BS2
First, my project is to control a·lamp level depending on the light in the room using light sensor wirelessly
so on the receiving part i use BS2 and get the transmited signal using wireless receiver then take an output
to the lamp
this is the code of the receiver
'{$STAMP BS2}
' {$PBASIC 2.5}
datas VAR Byte
i VAR Byte
check:
SERIN 7, 16780, [noparse][[/noparse]WAIT("*!"), DEC2 datas]
PAUSE 300
DEBUG DEC2 datas, CR
IF datas = 1 THEN one
IF datas = 2 THEN two
IF datas = 3 THEN three
IF datas = 4 THEN four
IF datas => 5 THEN five
one:
DEBUG "Level 1", CR
FOR i = 0 TO 5
PWM 4,255,255
NEXT
GOTO check
two:
DEBUG "Level 2", CR
FOR i = 0 TO 5
PWM 4,191,255
NEXT
GOTO check
three:
DEBUG "Level 3", CR
FOR i = 0 TO 5
PWM 4,127,255
NEXT
GOTO check
four:
DEBUG "Level 4", CR
FOR i = 0 TO 5
PWM 4,63,255
NEXT
GOTO check
five:
DEBUG "Level 5", CR
FOR i = 0 TO 5
PWM 4,0,255
NEXT
GOTO check
but i have three problems:
1-the BS2 can't switch on a 2.5V lamp but it do with LED , is because the output current is very small (20mA)??? if it is what is the solution??
2-the LED is blinking··how can i let it work continuesly (because of the FOR loop)??
3-how to let the lamp work continuesly until the level is changed
·i already use voltage·amplifier but make no difference
to the lamp
'{$STAMP BS2}
' {$PBASIC 2.5}
datas VAR Byte
i VAR Byte
check:
PAUSE 300
one:
DEBUG "Level 1", CR
FOR i = 0 TO 5
PWM 4,255,255
NEXT
GOTO check
two:
DEBUG "Level 2", CR
FOR i = 0 TO 5
PWM 4,191,255
NEXT
GOTO check
three:
DEBUG "Level 3", CR
FOR i = 0 TO 5
PWM 4,127,255
NEXT
GOTO check
four:
DEBUG "Level 4", CR
FOR i = 0 TO 5
PWM 4,63,255
NEXT
GOTO check
five:
DEBUG "Level 5", CR
FOR i = 0 TO 5
PWM 4,0,255
NEXT
GOTO check
It provides material on driving larger loads and how to control a device at varying levels continually using a small fan.
-Martin
Martin Hebel
StampPlot - Graphical Data Acquisition and Control
AppBee -·2.4GHz Wireless Adapters & transceivers·for the BASIC Stamp & Other controllers·
Here's a bit of code that might help you out as well. Whenever you see a series of routines that are almost alike, it is often possible to shrink things a bit.
'{$STAMP BS2}
' {$PBASIC 2.5}
datas VAR Byte
i VAR Byte
PWMval var byte
check:
PAUSE 300
if datas > 5 then
datas=5
PWMval=0
else
PWMval=255-((datas-1)*63)
endif
DEBUG "Level ",dec datas, CR
FOR i = 0 TO 5
PWM 4,PWMval,255
NEXT
GOTO check
I haven't tested this but I think it's good to go.
Lee
