Seven-segment display object
Here's a general-purpose seven-segment display object. It will control from one to eight digits.
OS-X: because making Unix user-friendly was easier than debugging Windows
links:
My band's website
Our album on the iTunes Music Store
links:
My band's website
Thank you for your time.
This driver works with any number of digits, digits must be on contiguous pins, with the low digit on the low digit-select pin.
The segments are also required to be on contiguous pins, but the order can be re-arranged by editing a lookup table.
Reads characters from a text string to write to the display, numbers "0" through "9", minus "-", decimal point ".", and space " " are recognized.
Includes methods for creating a string from integer values, or from an integer with a divider to a specified number of decimal places.
Works with common-anode and common-cathode displays, and also with transistor-driven displays.
for 8 digits (or 8 pins for 7 digits without DP).
Okay, just added a Charlieplexer to the obex. Nine pins gets you nine 7-segment displays with decimal points, additional displays require additional pins. This driver supports as many displays as you have pins for. Tested it with 10 displays with no noticeable flicker.
